Pretty famous picture- Gimli glider and Formula Fords
The Gimli Glider Incident
from an article published in Soaring Magazine by Wade H.Nelson
      If a Boeing 767 runs out of fuel at 41,000 feet what do you have? Answer: A 132 ton glider with a sink rate of over 2000 feet-per-minute and marginally enough hydraulic pressure to control the ailerons, elevator, and rudder.  Put veteran pilots Bob Pearson and cool-as-a-cucumber Maurice Quintal in the in the cockpit and you've got the unbelievable but true story of Air Canada Flight 143, known ever since as the Gimli Glider.
      Flight 143's problems began on the ground in Montreal.  A computer known as the Fuel Quantity Information System Processor manages the entire 767 fuel loading process.  The FQIS controls all of the fuel pumps and drives all the 767's fuel gauges.  Little is left for crew and refuelers to do but hook up the hoses and dial in the desired fuel load.  But the FQIS was not working properly on Flight 143. The fault was later discovered to be a poorly soldered sensor.  A highly improbable, one-in-a-million sequence of mistakes by Air Canada technicians investigating the problem defeated several layers of redundancy built into the system.  This left Aircraft #604 without working fuel gauges.
      In order to make their flight from Montreal to Ottawa and on to Edmonton, Flight 143's maintenance crew resorted to calculating the 767's fuel load by hand.  This was done using a procedure known as dripping the tanks.
      "Dripping" could be compared to calculating the amount of oil in a car based on the dipstick reading.  Among other things, the specific gravity of jet fuel is needed to make the proper drip calculations.
      The flight crew had never been trained how to perform the drip calculations.  To be safe they re-ran the numbers three times to be absolutely, positively sure the refuelers hadn't made any mistakes;each time using 1.77 pounds/liter as the specific gravity factor.  This was the factor written on the refueler's slip and used on all of the other planes in Air Canada's fleet.  The factor the refuelers and the crew should have used on the brand new, all-metric 767 was 0.8 kg/liter of kerosene.
      After a brief hop Flight 143 landed in Ottawa.  To be completely safe, Pearson insisted on having the 767 re-dripped.  The refuelers reporting the plane as having 11,430 liters of fuel contained in the two wing tanks.  Pearson and Quintal, again using the same incorrect factor used in Montreal, calculated they had 20,400 kilos of fuel on board.  In fact, they left for Ottawa with only 9144 kilos, roughly half what would be needed to reach Edmonton.
      Lacking real fuel gauges Quintal and Pearson manually keyed 20,400 into the 767's flight management computer.  The flight management computer kept rough track of the amount of fuel remaining by subtracting the amount of fuel burned from the amount (they believed) they had started with.  Their fate was now sealed.
      According to Pearson, the crew and passengers had just finished dinner when the first warning light came on.  Flight 143 was outbound over Red Lake Ontario at 41,000 feet and 469 knots at the time.  The 767's Engine Indicator and Crew Alerting System beeped four times in quick succession, alerting them to a fuel pressure problem.  "At that point," Pearson says, "We believed we had a failed fuel pump in the left wing, and switched it off.  We also considered the possibility we were having some kind of a computer problem.  Our flight management computer showed more than adequate fuel remaining for the duration of the flight.  We'd made fuel checks at two waypoints and had no other indications of a fuel shortage."  When a second fuel pressure warning light came on, Pearson felt it was too much of a coincidence and made a decision to divert to Winnipeg.  Flight 143 requested an emergency clearance and began a gradual descent to 28,000.  Says Pearson, "Circumstances then began to build fairly rapidly." The other left wing pressure gauge lit up, and the 767's left engine quickly flamed out.  The crew tried crossfeeding the tanks, initially suspecting a pump failure.
      Pearson and Quintal immediately began making preparations for a one engine landing.  Then another fuel light lit up.  Two minutes later, just as preparations were being completed,the EICAS issued a sharp bong — indicating the complete and total loss of both engines.  Says Quintal, "It's a sound that Bob and I had never heard before. It's not in the simulator."  After the "bong," things got quiet.  Real quiet.  Starved of fuel, both Pratt & Whitney engines had flamed out.  Pearson's response, recorded on the cockpit voice recorder was, "Oh f%@&."
      At 1:21 GMT, the forty million dollar, state-of-the-art Boeing 767 had become a glider.  The APU, designed to supply electrical and pneumatic power under emergency conditions was no help because it drank from the same fuel tanks as the main engines.  Approaching 28,000 feet the 767's glass cockpit went dark. Pilot Bob Pearson was left with a radio and standby instruments, noticeably lacking a vertical speed indicator - the glider pilot's instrument of choice.  Hydraulic pressure was falling fast and the plane's controls were quickly becoming inoperative.  But the engineers at Boeing had foreseen even this most unlikely of scenarios and provided one last failsafe — the RAT.
      The RAT is the Ram Air Turbine, a propeller driven hydraulic pump tucked under the belly of the 767.  The RAT can supply just enough hydraulic pressure to move the control surfaces and enable a dead-stick landing.  The loss of both engines caused the RAT to automatically drop into the airstream and begin supplying hydraulic pressure.
      As Pearson began gliding the big bird, Quintal "got busy" in the manuals looking for procedures for dealing with the loss of both engines.  There were none...  Neither he nor Pearson nor any other 767 pilot had ever been trained on this contingency.  Pearson reports he was thinking "I wonder how it's all going to turn out."  Controllers in Winnipeg began suggesting alternate landing spots, but none of the airports suggested, including Gimli, had the emergency equipment Flight 143 would need for a crash landing.  The 767's radar transponder had gone dark leaving controllers in Winnipeg using a cardboard ruler on the radar screen to try and determine the 767's location and rate of descent.
      Pearson glided the 767 at 220 knots, his best guess as to the optimum airspeed.  There was nothing in the manual about minimum sink - Boeing never expected anyone to try and glide one of their jet airliners.  The windmilling engine fans were creating enormous drag, giving the 767 a sink rate of somewhere between 2000 and 2500 fpm.  Copilot Quintal began making glide-slope calculations to see if they'd make Winnipeg.  The 767 had lost 5000 feet of altitude over the prior ten nautical (11 statute) miles, giving a glide ratio of approximately 11:1.  ATC controllers and Quintal both calculated that Winnipeg was going to be too far a glide; the 767 was sinking too fast.  "We're not going to make Winnipeg" he told Pearson.  Pearson trusted Quintal, and immediately turned north.
      Only Gimli, the site of an abandoned Royal Canadian Air Force Base remained as a possible landing spot.  It was 12 miles away.  It wasn't in Air Canada's equivalent of Jeppensen manuals, but Quintal was familiar with it because he'd been stationed there in the service.  Unknown to him and the controllers in Winnipeg, Runway 32L (left) of Gimli's twin 6800 foot runways had become inactive and was now used for auto racing.  A steel guard rail had been installed down most of the southeastern portion of 32L, dividing it into a two lane dragstrip.  This was the runway Pearson would ultimately try and land on, courting tragedy of epic proportions.
      To say that runway 32L was being used for auto racing is perhaps an understatement.  Gimli's inactive runway had been "carved up" into a variety of racing courses, including the aforementioned dragstrip.  Drag races were perhaps the only auto racing event not taking place on July 23rd, 1983 since this was "Family Day" for the Winnipeg Sports Car Club.  Go-cart races were being held on one portion of runway 32L and just past the dragstrip another portion of the runway served as the final straightaway for a road course.  Around the edges of the straightaway were cars, campers, kids, and families in abundance.  To land an airplane in the midst of all of this activity was certain disaster.
      Pearson and Copilot Quintal turned toward Gimli and continued their steep glide.  Flight 143 disappeared below Winnipeg's radar screens, the controllers frantically radioing for information about the number of "souls" on board.  Approaching Gimli, Pearson and Quintal made their next unpleasant discovery: The RAT didn't supply hydraulic pressure to the 767's landing gear.  Pearson ordered a "gravity drop" as Pearson thumbed frantically through the Quick Reference Handbook, or QRH.  Quintal soon tossed the QRH aside and hit the button to release the gear door pins.  They heard the main gear fall and lock in place.  But Quintal only got two green lights, not three.  The nose gear, which fell forward against the wind, hadn't gone over center.
      Six miles out Pearson began his final approach onto what was formerly RCAFB Gimli.  Pearson says his attention was totally concentrated on the airspeed indicator from this point on.  Approaching runway 32L he realized he was too high and too fast, and slowed to 180 knots.  Lacking divebrakes, he did what any sailplane pilot would do: He crossed the controls and threw the 767 into a vicious sideslip.  Slips are normally avoided on commercial flights because of the the tremendous buffeting it creates, unnerving passengers.  As he put the plane into a slip some of Flight 143's passengers ended up looking at nothing but blue sky, the others straight down at a golf course.  Says Quintal, "It was an odd feeling.  The left wing was down, so I was up compared to Bob.  I sort of looked down at him, not sideways anymore.
      The only problem was that the slip further slowed the RAT, costing Pearson precious hydraulic pressure.  Would he be able to wrestle the 767's dipped wing back up before the plane struck the ground?  Trees and golfers were visible out the starboard side passengers' windows as the 767 hurtled toward the threshold at 180 knots, 30-50 knots faster than normal.  The RAT didn't supply "juice" to the 767's flaps or slats so the landing was going to be hot.  Pearson didn't recover from the slip until the very last moment.  A passenger reportedly said "Christ, I can almost see what clubs they are using."  Copilot Quintal suspected Pearson hadn't seen the guardrail and the multitude of people and cars down the runway.  But at this point it was too late to say anything.  A glider only gets one chance at a landing,and they were committed.  Quintal bit his lip and remained silent.
      Why did Pearson select 32L instead of 32R? Gimli was uncontrolled so Pearson had to rely on visual cues.  It was approaching dusk.  Runway 32L was a bit wider, having been the primary runway at Gimli in prior year.  Light stantions still led up to 32L.  And the "X" painted on 32L, indicating its inactive status, was reportedly quite faded or non-existent.  Having made an initial decision to go for 32L the wide separation of the runways would have made it impossible for Pearson to divert to 32R at the last moment.  Pearson says he: "Never even saw 32R, focusing instead on airspeed, attitude, and his plane's relationship to the threshold of 32L."
      The 767 silently leveled off and the main gear touched down as spectators, racers, and kids on bicycles fled the runway.  The gigantic Boeing was about to become a 132 ton, silver bulldozer.  One member of the Winnipeg Sports Car Club reportedly was walking down the dragstrip, five gallon can full of hi-octane racing fuel in hand, when he looked up and saw the 767 headed right for him.  Pearson stood on the brakes the instant the main gear touched down.  An explosion rocked through the 767's cabin as two tires blew out.  The nose gear, which hadn't locked down, collapsed with a loud bang.  The nose of the 767 slammed against the tarmac, bounced, then began throwing a three hundred foot shower of sparks.  The right engine nacelle struck the ground.  The 767 reached the tail end of the dragstrip and the nose grazed a few of the guardrail's wooden support poles.  (The dragstrip began in the middle of the runway with the guardrail extending towards 32L's threshold) Pearson applied extra right brake so the main gear would straddle the guardrail.  Would all the sports car fans all be able to get out of the way, or would Pearson have to veer the big jet off the runway to avoid hitting stragglers?
      The 767 came to a stop on it's nose, mains, and right engine nacelle less than a hundred feet from spectators, barbecues and campers.  All of the race fans had managed to flee the path of the silver bulldozer.  The 767's fuselage was intact.  For an instant,  there was silence in the cabin.  Then cheers and applause broke out among Flight 143's passengers.  They'd made it; they were all still alive.  But it wasn't over yet.  A small fire had broken out in the nose of the aircraft.  Oily black smoke began to pour into the cockpit.  The fiery deaths of passengers in an Air Canada DC-9 that had made an emergency landing in Cincinnati a month before was on the flight attendants' minds and an emergency evacuation was ordered.  The unusual nose-down angle the plane was resting at made the rear emergency slides nearly vertical.  Descending them was going to be treacherous.
      The only injuries that resulted from Pearson's dead-stick landing of Flight 143 came from passengers exiting the rear emergency slide hitting the asphalt.  None of the injuries were life-threatening.  The fire in the aircraft's nose area was battled by members of the Winnipeg Sports Car Club who converged on the plane with dozens of hand-held fire extinguishers.  Pearson had touched down 800 feet from the threshold and used a mere 3000 feet of runway to stop.  A general aviation pilot who viewed the landing from a Cessna on the apron of 32R described it as "Impeccable."  The 767 was relatively undamaged.
      Air Canada Aircraft #604 was repaired sufficiently to be flown out of Gimli two days later.  After approximately $1M in repairs, consisting primarily of nose gear replacement, skin repairs and replacement of a wiring harness it re-entered the Air Canada fleet.  To this day Aircraft #604 is known to insiders as "The Gimli Glider."  The avoidance of disaster was credited to Capt. Pearson's "Knowledge of gliding which he applied in an emergency situation to the landing of one of the most sophisticated aircraft ever built."  Captain Pearson strongly credits Quintal for his cockpit management of "Everything but the actual flight controls," including his recommendation of Gimli as an landing spot.  Captains Pearson and Quintal spoke at the 1991 SSA Convention in Albuquerque about their experiences.  Pearson was, at the time, still employed and flying for Air Canada, and occasionally flying his Blanik L-13 sailplane on the weekends; he has since retired to raise horses.  Maurice Quintal is now an A-320 Pilot for Air Canada,and will soon be captaining 767's; including Aircraft #604.
Copyright 1997 WHN
An amusing side-note to the Gimli story is that after Flight 143 had landed safely, a group of Air Canada mechanics were dispatched to drive down and begin effecting repair.  They piled into a van with all their tools.  They reportedly ran out of fuel en-route, finding themselves stranded somewhere in the backwoods of Manitoba.
Credits:
Special thanks to William and Marilyn Mona Hoffer, authors of "Freefall, A True Story" (ISBN 0-312-92274-4), Boeing Aircraft 767 Chief Engineer Hank Queen, Mr. Len Gelfand, Colin Nisbet, Don Sigmundson, Don Kawal, Robert Pearson, Maurice Quintal, and many others.
Photo / Illustration Credits:  Sports Cars / 767 on Nose by Wayne Glowacki, Gimli from the air Anders Kuusselka
Boeing 767 photo (link: Gimli Glider)
Thank you for posting this story. For several years after moving into Manitoba, I wasn't even aware of the Gimli Glider incident. Once I heard about it, I started to read a bit about it. As a gearhead I was always wondering how this plane could have run out of fuel less than halfway through its journey, and it was almost impossible to find the answer for that. Virtually every article about it just mentions a "mistake", usually attributed to the difference between the metric and the imperial measuring system.
Even the article provided here does not properly explain this huge error by the pilots. The author talks about the fact that the pilots used a factor of 1.77  pounds per liter when in fact they should have used 0.8kg/ltr. This does make no sense, because 1.77 lbs are 0.8045 kg, meaning that using the non-metric conversion factor would have still yielded very close to the correct amount; as a matter of fact, they would have had a tiny amount of fuel more than what they calculated as needed.
The real issue is addressed in this sentence: "The refuelers reporting the plane as having 11,430 liters of fuel contained in the two wing tanks.  Pearson and Quintal, again using the same incorrect factor used in Montreal, calculated they had 20,400 kilos of fuel on board." Incorrect factor or not, the problem actually was the math skills of the pilots. 11430 liters of fuel are  9144 kg when using the right conversion factor, or 20231.1 lbs of fuel when using the incorrect (imperial) conversion factor. Please note that the difference between the metric and the imperial conversion factor is the difference between 9144 kg and 9195.95 kg - a negligible difference of 52 kg (or 114 lbs). However, based on the article and the numbers mentioned, it appears that the captain did his math, for whatever unexplained reason rounded the number 20231 up to 24000 and called it Kilograms, instead of Pounds. And this seems to be the reason why they ended up with less than half the fuel that they needed to make it to Edmonton. This had nothing to do with the wrong conversion factor, it was all caused by the pilots not understanding the difference between Kilograms and Pounds. Bear in mind that this incident happened after Canada had already converted to the metric system some three years prior, and that the Boeing 767 was well-known to be running on Metric calculations!
I have read several articles about how various airlines programmed this emergency landing into their simulators, and how for numerous years other pilots were unable to produce this landing on a simulator. Bob Pearson was heralded as a hero and outstanding pilot because of this landing. I, however, sit firmly in the camp of people who believe that Pearson should have been dragged to court over this. There was a huge amount of gross negligence and incompetence displayed by both pilots. Pearson's quality as glider pilot may be remarkable; his rudimentary lack of ability to calculate and properly program what is arguably the most important number of any flight was down-right criminal. As opposed to Chesley Sullenberger's emergency landing on the Hudson River, the Gimli Glider incident was completely avoidable and solely based on the poor skills of the two pilots. The fact that they didn't kill anyone by making such an inexcusable mistake should not earn them a hero status.
Fast-forward around two decades: an aircraft occupied by four persons ran out of fuel and did an emergency landing on the intersection of McPhillips Street and Logan Avenue. Unfortunately, this landing was not quite as smooth, and not everybody survived it. The pilot of that flight was never called a hero. The justice system made it quite clear that passengers are entitled to expect professional conduct by the pilot, and running out of fuel constituted a complete lack of care for the safety of his passengers.
But overall, through the eyes of Gimli and the WSCC, this is a remarkable story. I am sure there are still people in our club that were present at that day, and I would love to hear about this incident from a person who actually witnessed it. From what I understand, the plane kind of landed between the kart racers and the road race staging area. Nevertheless, with the engines being off and the plane not having a horn to warn people, that incoming bird must have been quite a surprise. I am sure the race schedule was thrown off a bit that day, as well...
  • Thanks 1
Not to hijack your thread here, excuse the pun, but I witnessed a similar mishap at Gimli, about 7 or 8 years ago. We were drag racing that day, and we watched a little yellow plane come down and land between the strip and the kart track, right where we do the slalom for the HPDE. He got turned around and took off again, but a friend of mine sent his picture to the Winnipeg Sun (I think) and I remember they posted it. I looked around for a link, to no avail.
The story I heard later was that he got confused about which runway to land on, I always wondered if he got in any trouble for that. But being there and watching this was intense, and you can guess the first two words out of anyone's  mouth that day. Gimli Glider. This was a lot smaller scale of course, but it gave me a very real feel for how nuts it must have been when that big plane dropped in without a sound.
  • 2 weeks later...
I was a member of the WSCC "ground crew" when the Gimli glider made its landing.
I reject Mr. Ofusio's damning comment about the pilot's inability to calculate the right fuel load. On talking with pilot Pearson, he pointed out that they were trained for a three-person cockpit. Air Canada decided to have only 2 people in the cockpit, but failed to give the pilots the information needed to be able to properly calculate their fuel.
Another thing ignored, was when pilots were faced with an impossible situation, they used their aeronautical skills to successfully land a 200 ton "rock" without causing any death either on the aircraft or on the ground. This problem has been programmed into simulators, but no other pilot has been able to successfully complete the landing.
What's more, the airplane was repaired and put back into service for another 25 years.
Now CG-AUN rests in the Arizona desert and is slowly being parted out.
I bought a part of the fuselage converted to a baggage tag from a company that specializes in this from retired aircraft. I keep it as momento of that day.
That is neat! No such thing as computer printouts then! It is nice to see what people were racing then, although I have no idea what a Johnson is. There are some cars listed in the class "Michelin" - was that a spec tire class?
I also don't see any Time Attack on those pages. I understand that Time Attack is a fairly recent addition to the races. When did it start?
So much history in this club...
Edited by donrolandofurioso
The Michelin class was a special version of a Honda Civic. Under the name 'Honda Michelin class'. A very base model with a 1300cc engine. (most road models were 1500cc at the time). You bought the car through a Honda dealer. Signed papers that it was being used for racing. And there was a lot with the car that included an exhaust bypass pipe. A bolt in roll cage, and a set of 390mm in diameter alloy wheels with Michelin TRX tires. The Michelin TRX tires were available in 365mm. & 390 mm. diameters rather than the conventional 13",14",15", etc. tire and wheel dimensions. Some might say Michelin's attempt to reinvent the wheel. (that may have been funnier live). The Honda Michelin was a National series. Obviously much bigger down east in Ontario & Quebec.
.The race schedule of the Gimli glider weekend wasn't impacted at all. Since the aircraft landed on Saturday evening. After the days race schedule was run.
   The club secured all the entrances to the property with volunteers.  In those days there were more roads and accesses to the track than there is today. Air Canada hired security guards that arrived Sunday morning to secure the perimeter of the aircraft.
   We ran a regular Sunday race schedule. With the help of the additional workers blocking the additional entrances. And the Kart Racers ran there regular Sunday schedule as well. (at the North end of the main straight, where the current Drag Racing paddock is located.
   I was Kart racing that weekend. And at the time believe I was Club Secretary. Dave Sargent was Race Director, John Webb was President.
  • 3 months later...
I was crewing for Vince Squib and Hank Marcoux that weekend. Racing was done for the day, and I debated with my buddy to pitch a tent or head back to Winnipeg for a comfortable bed. We elected to head back. We missed the landing by about 10 minutes, but our jaws sure dropped when we turned the corner and saw it on the ground early the next morning.
Vince emptied a fire extinguisher into the nose gear compartment to help put out the small hydraulic fire, which left us one short the next day. But we found another for our pits, and we were good to go. (I think it took Air Canada over two years to reimburse us for the refill on the extinguisher, but I am guessing they were busy adding up a few more costs involved in that incident than just ours.)
I ran into Hank Marcoux a few times over the years and became his assistant instructor for our club's track days - which helped immensely when I went on to test and write about police cars for part of what my spouse laughingly refers to as "a living." I sadly lost touch with Vince after he closed his shop and moved over to Metro Motors. We sure had some great parties, both at his place in Winnipeg and at the track. Great memories. I still have a few photos of the Ford-sponsored Mustang that ran in the 1980s, with more money invested in team shirts than we had in our whole race team.
I recently read that the Gimli Glider was now up for sale, although the bidding didn't meet the owner's minimum. It was an amazing example of pilotage.
