conebasher Posted September 28, 2024 Posted September 28, 2024 Yes, it's true, the Shell at Madison Square across from Polo park has 93 octane fuel and I think it's important to support this so they keep carrying it. I fuel up all my vehicles with it even though only the Camaro benefits from the high octane. 1
Brian_Earl_Spilner Posted October 1, 2024 Posted October 1, 2024 Is it actually 93 though? Do they still have 91 as well? Curious if the same tanker trucks that make the rounds to stations with 91 just drop by there as well, or if they have a one-off truck that delivers 93. Not sure how the logistics would make sense for only a single station (or two) to have 93.
conebasher Posted October 2, 2024 Author Posted October 2, 2024 10 hours ago, Brian_Earl_Spilner said: Is it actually 93 though? Do they still have 91 as well? Curious if the same tanker trucks that make the rounds to stations with 91 just drop by there as well, or if they have a one-off truck that delivers 93. Not sure how the logistics would make sense for only a single station (or two) to have 93. I could have predicted your skeptical response. They have 93 on only 2 pumps, the rest have 91
conebasher Posted October 12, 2024 Author Posted October 12, 2024 The Shell on Pembina close to mcGillivry also has 93 octane now 1
Brian_Earl_Spilner Posted October 29, 2024 Posted October 29, 2024 The Shell on Sterling Lyon by Rec Room also now has 93.
Curtis Posted October 29, 2024 Posted October 29, 2024 9 hours ago, Brian_Earl_Spilner said: The Shell on Sterling Lyon by Rec Room also now has 93. Is it actually 93 though? Do they still have 91 as well? Curious if the same tanker trucks that make the rounds to stations with 91 just drop by there as well, or if they have a one-off truck that delivers 93. Not sure how the logistics would make sense for only a single station (or two) to have 93.
conebasher Posted October 30, 2024 Author Posted October 30, 2024 12 hours ago, Curtis said: Is it actually 93 though? Do they still have 91 as well? Curious if the same tanker trucks that make the rounds to stations with 91 just drop by there as well, or if they have a one-off truck that delivers 93. Not sure how the logistics would make sense for only a single station (or two) to have 93. I dyno tested the Camaro with Shell 91 and got up to 4 degrees of Knock Retard from 3600 rpm all the way to 7000 rpm then went back with Shell 93 and running the exact same tune, I got less than .5 degrees blip of Knock Retard at 4600 rpm. On a side note, I then added some Boostane (purchased from Phil at www.fasttoys.net) and was able to add 6 degrees of timing without getting any Knock Retard, so that stuff really works at increasing octane levels.
Brian_Earl_Spilner Posted October 30, 2024 Posted October 30, 2024 13 hours ago, Curtis said: Is it actually 93 though? Do they still have 91 as well? Curious if the same tanker trucks that make the rounds to stations with 91 just drop by there as well, or if they have a one-off truck that delivers 93. Not sure how the logistics would make sense for only a single station (or two) to have 93. Good question. I'm not sure.
Register a new accountSign in
