Magner
Car Classing Guide + Help Thread
Will i fall under stx class if i install those tower struts and wider set of tires and rims? Thanks for the help!
Not sure what model car this is referencing but STX does allow strut tower bars, note you can only add a tower bar with 2 attachment point. A 3 point is only allowed if you are replacing a factory oem 3 point bar, see 14.2.G in the SCCA solo rulebook for more info if this applies to you. Wheels in STX are up to 8.0 inches for AWD cars and 9.0 inches for 2wd cars (14.4 for more info).
Hope that helps!
  • Thanks 1
Bump, original post updated with 2018 links and season changes. Post any questions here.
  • Thanks 1
Hi Good day to all! Had a blast with our 1st event today and nice to see familiar faces again! i got a question if anybody could help me please? i installed a lowering springs for my mini and nothing else, do i fall under stx class for it? Please and thanks!
I'm guessing you have a 2005 Mini Cooper S? (Yr and model may vary the class). If so, changing springs will keep you in STX.
Spring are legal in all ST, SP, SM, P, M and CAM classes. The only class you CANNOT install aftermarket springs in is "Street" class.
Michelle's car is a 2012 VW Golf with the 2.5L engine (5 cylinders, 20 valves). Car is stock. I could not find where it would actually fit without using the top most catch all for SS. The car is basically a Jetta so I classed her in HS but not sure that is appropriate. Also I notice that the classing sometimes mentions the 2.5L and just that and sometimes as 2.5L 5-cyl.
I had a look on page 157 of the 2018 rule-book and noticed the same. This comes up often in SCCA fastracks updates. Not EVERY car is classed in street. there's always clarifications and model splitting going on.  With your situation it's safe to assume the they intent is to include the Golf 2.5 in HS with the "Jetta 2.5". The "Golf GTI & Jetta (16v non turbo)" line realistically should just drop the 16v verbiage to include 20v. I doubt there's many Golf 2.5L's running so his has never been brought up. I assume this 2.5L is N/A? Looks like the turbo Golf of this generation would be under GS not HS. Also is the Golf with a 2.5L available in the States too or is that a Canada only model?
It is just a NA motor, no turbo, and it was available in the US...so it's probably just not really being run at events. It for sure is nothing to write home about but it's a decent DD.
Yes the rulebook states all Honda Accords are in H-Street
Hey guys. So i have a 2000 Forester s/tb (turbocharged) with some modifications. The car is imported from Japan, i'm unsure on what class i fall into with it since its rhd and had some add ons. any help would be great. thanks
add ons are-
06 sti suspension, full exhaust, aftermarket sway bars and end links, larger oem turbo, upgraded fuel system, turbo inlet, intercooler hoses, boost controler, custom tuning, rpf1 wheels with firestone firehawk indy 500 tires (340 tread wear) ,
interior is all factory, braking system is factory.
add ons are-
All jdm automatically goes to Street Modified.
You will be in SM-S
With your modifications you’d end up there anyway in a nadm car
You will be in SM-S
Thank you Joe! appreciate the reply!
Hi, I’m running a 2018 Kia stinger gt. All stock. Just wondering what class in street it falls under.
Hi, I just reviewed the current 2018 Rulebook and all addendums since its release. At this time I do no see any classing for the new Kia Stinger. The official class at this time is Super Street (SS) under the "catch-all" however I expect this to be officially classed somewhere else when reviewed.
I'll keep an eye out and report back if I see a listing.
Hello All,
I apologize in advance for my noob level here but as I have just registered for my first event ever, I'm hoping someone can confirm that I have elected to enter my vehicle into the appropriate class. I have chosen STX as I believe it is the correct class for my 2017 Toyota 86 with its current modifications. These modifications include:
- Enkei RPF1 Wheels (17x9 +35)
- Bridgestone RE-71R Tires (245/40R17)
- TRD Lowering Springs
- SPC Camber Bolts (front)
- TRD Catback Exhaust
- Berk Front Pipe w/HFC (catalytic converter is in the same position as the OEM frontpipe)
- Mtech Shifter Return Springs
Please advise on the classification I have chosen.
Thanks,
Louis
Good to go! Everything you listed is legal for Street Touring (ST). Great package for a competitive start to STX.
