SoloSnapshots
Classing help (old)
2000 Ford Focus ZX3Mods:Lowering Springs - ST legalCross Drilled Front Rotors - ST legalSS Brake Lines - ST legal if DOT approvedShort Ram Style Intake - ST legalEBC Ceramic Brake Pads (Greenstuff) - Stock legalIf you remove all but the brake pads you're good to go in H-Stock. If your tires aren't wider than 225 and your wheels aren't wider than 7.5" then your in STS. Same goes for J. C.
Cool, my tires are 195s currently and 6.5" Rims. What other types of cars run in STS? I don't expect to be competitive this year, but I'm wondering if there would even be a faint hope if I happen to do well
2003 Subaru Impreza WRXMods:Perrin Light-Weight Crank PulleyPerrin Cat-Less Up-PipeGReddy Racing Turbo Ti-C Cat-Back ExhaustAm I STX?
If you still have at least one cat, your rims are a maximum of 8" wide and your tires are a maximum of 245mm wide then you'd be in STX.For anyone running Street Touring and has done exhaust modifications remember this rule
14. STREET TOURING CATEGORY14.10 ENGINEEngine and transmission must remain unmodified, including emissionsequipment, except as noted below. All emissions monitoring system hardware and software must be operationally functional as originally intended by the manufacturer. Tampering with emissions system software and/or hardware to create or cloak non-compliance is not permitted. Some examples of emissions system tampering are O2 foolers, disabling or deactivating Check Engine Light (CEL) code indication, backdating ECU internals from OBD2 to OBD1, etc.
Ok well with the cat-less up-pipe there is a resistor that is inserted in the harness that was connected to the egt sensor. I still have 2 cats left but eventually getting rid of them by next year and getting a cobb accessport to remove the CEL. So for now I'm STX but after I get my cat-less down-pipe and the other cat that connects the mid-pipe and down-pipe what class would I be in? Sorry I read the .pdf file but it's a little hard to understand.
You'd be in ESP.
15. STREET PREPARED CATEGORY15.10 ENGINE AND DRIVE TRAINF. Emission control devices may be modified or removed. This permits the oil filler cap to be modified or substituted, but does not allow valve covers or cam covers to be altered to install a breather or for any other purpose.I. Exhaust manifolds and muffler systems are free, except that they must be quiet and terminate behind the driver. Exhaust heat shields may be removed. Rear- and mid-engine cars without exhaust headers/manifold systems may use any exhaust system that meets the requirements of 3.5. This permits the removal of “heater boxes” in order to install headers on such cars.
'99 Acura 1.6EL-H&R Sport springs, KYB AGX struts, Skunk2 LCA's, factory sized wheels with 205/50/15 street tires, KVR rotors, Hawk HPS pads, stainless brake lines all around, stock drums on back, warm air intake, airbags removed, I'm thinking I should be in FSP-S?
airbags removed
The passenger side airbag is removed too? If it is is it physically removed or is it just disconnected?
Physically removed, replaced by a block-off tray.
That'll take you out of FSP
15. STREET PREPARED CATEGORY15.2 BODYWORKH. Driver and front passenger airbags may be electrically disabledbut not removed.
You'd be in E-Prepared.
That'll take you out of FSPYou'd be in E-Prepared.
Hmmm, is there even anyone else competing in this class locally? This is what I get for building my car for me, and not for autoX eh Joe, lol.
You'll be in the same group as the Street Prepared, Street Modified, Prepared and Modified guys. If you had all the airbags in you'd be in STS.
i was in DSS last year and this year i believe i will be under STS, but im not 100% sure which subsection of STS i would be in.
I'm not sure if you'd be there but STS is the class. Street Touring is STS, STS2, STX and STU.
Hmmm' date=' is there even anyone else competing in this class locally? This is what I get for building my car for me, and not for autoX eh Joe, lol.[/quote']Forgot about it earlier but your side skirts would have also take you out of SP. They're allowed in Street Touring but not in Street Prepared.
14. STREET TOURING CATEGORY14.2. BODYWORKF. Addition of spoilers, splitters, body kits, rear wings and nonfunctional scoops/vents is allowed. The intent of this allowance is to accommodate commonly available appearance kits, and replicas thereof, which have no significant aerodynamic function at Solo speeds. Body kits are limited to bumper covers, valances, side skirts, and fender flares. Standard parts may not be removed except for the substitution of spoilers, rear wings, bumper covers and valances. Rear wings must attach only aft of the rear wheel centerline.
15. STREET PREPARED CATEGORY15.2 BODYWORKI. Spoilers/splitters and cosmetic trim pieces are permitted. Side skirts may not be used. Spoilers/splitters must comply with the following subsections. The intent of this allowance is to accommodate commonly available appearance kits, and replicas thereof, which have no significant aerodynamic function at Solo speeds.
Wow, there is a LOT of rules in this sport, lol. Thanks for the help Steve.
Hey Steve, Could you confirm that my car would be SM? A quick perusal of the new ruleset leads me to believe that that is where my car would be....and since it's been awhile...92 Civic Si with suspension and boost.Thanks.
Nick, does that mean we'll be seeing you next weekend? :)
Nick' date=' does that mean we'll be seeing you next weekend? :)[/quote']Well, when I got home yesterday I jacked the car up, put in the racing suspension, cleaned and gapped the plugs, changed the oil and dug the R's out of the basement. So, yeah, I'm hoping to be there : ) I'm anxious to try it again and I didn't even see anybody racing, yesterday....and thanks, Steve.
Hey Steve I'm considering a car change right now...to a 2007 Cobalt SS, Non Supercharged. What class? F Stock? Where is the online documents that show classing rules, I figure you must know since you practically have all of them memorized, lol
can some one tell me what class stock impreza would be?
Impreza WRX STi is A-StockImpreza WRX is D-StockImpreza with a non-turbo 2.5L is G-StockImpreza (other) is H-Stock
In hopes of actually running my car on Sunday I want to know what class I am in. I think I will be ESP. 2004 Audi S4, H-Sport front and rear anti-sway bars, everything else is stock. Shawn
In hopes of actually running my car on Sunday I want to know what class I am in. I think I will be ESP. 2004 Audi S4' date=' H-Sport front and rear anti-sway bars, everything else is stock. Shawn[/quote']I believe if you put your stock rear bar back on then you can run in Stock.
With a stock rear bar if everything else is stock legal you'd be in DS.
Guest
This topic is now closed to further replies.
