Korey p
I need help for class and pax for registering!!
Hey guys I need help which class and pax I need to pick for registering since I have changed a couple things on my car if someone could help it would be much appreciated! Below is a list I've done in the last year to my car since I bought it.
2000 honda s2000
Clutch master cylinder oem replacement
Slave cylinder oem replacement
DOT4 brake and clutch fluid change
Upgraded rad hoses
Mishimoto triple core rad
AEM cold air intake
Valve seals and retainers
Valve adjustment
(Secondary air pump deteled and EGR
Minus 7.2lbs off car izze racing wiring harness replaces that)
Izze racing EGR block off plate
PVC valve
Stock shocks
Motor mounts (lower engine only)
Soft top
Valve cover gasket kit
Laser cut spark plugs
Hood damper kit
Cooling plate
Battery time down JDM password
Thermostat oem
Idler pully
Serpentine belt
JDM password rad brackets
AMS oil change (engine/tranny/dif)
Coolant change
Stop tech stainless steel brake lines
Front lower ball joints oem
4 new sway links oem
Thanks in advance!!
What are you trying to register for? Autoslalom, road race, time attack, etc.?
If you are looking for Autoslalom, the car classing thread is here:
